Hesitating Bird (Part 2)
senna95
10-07-2003, 05:23 PM
I've checked the secondary resistance on the coil pak for the #2 & #5 cylinder and found it over spec limit. I pretty sure thats the problem. My question now is why is that paticular coil always crapping out? It will be the 4th time changing it. Could there be another issue causing the paks to malfunction? Such as the module that sits underneath them? I'm going to use a genuine GM coil pak this time because the after market paks I've purchased only come with a 90 warranty.
AnotherBreedRacing
10-16-2003, 02:07 AM
good idea yes it could be the actual module because it could have a serge point in it on those pitcular packs i would replace it if it acures again :banghead:
