AIR DRIED BEEF DOG FOOD
have ls/vtec but rpms seem to rise slow
furiousfob
10-07-2003, 04:28 AM
alright i have ls/vtec setup in a 95 teg ls. the problem is that the rpms seem to be rising very slowly. I'm guessing its because i still have my ls tranny.
B16EJ1
10-07-2003, 04:33 AM
That's most likely the problem. You need a DOHC VTEC tranny so you can fly through the RPM's to your powerband not to mention the higher final drive.
furiousfob
10-07-2003, 04:37 AM
oh yah i have a gsr head on my ls/vtec and i need to get headers cuz mine are all crushed from the previous owner. My question is are ls headers and gsr headers the same. which one will i need
PROFILEcivic01
10-07-2003, 11:24 AM
Check your firing order. I did an engine swap and had the same problem and it turned out that the firing order was not right.
94tegRS
10-08-2003, 02:17 AM
make sure your cams are timed together. trust me it makes a huge difference when they are off and it wasnt hard for me to mees uop the timing of mine. I was going to replace the timing belt, got everything loosened and off except the crank pulley, which wouldnt budge even with a impact wrench or huge breaker bar so I had to put it back together for the time being til i could fuinish it and I lined all the tabs/marks up and had the crank ligned dead on where it needed to be, had my dad with a couple ratchets hold the cams in the position they were supposed to be in. slipped the belt on and turned it a bit cc to build tension, tightened the tensioner, started it, no power at all, imtaling floor it in neutral and a full second later your at 3k, it used to take a second and a half about to hit 7k. and driving it is a biatch. I noticed that the intake is either retarded far or the exhaust is advanced far, or each a bit off. having really lined the crank up to check yet, but I can see the cams "up"s dont both go up at the same time. so maybe this is a problem.
B16EJ1
10-08-2003, 04:15 AM
They are the same.
