OIL IN #2 & #3 SPARK PLUG HELP!!
Hatchbacksi_novtec
09-30-2003, 05:16 PM
I was just wondering what could be causing oil to get into spark plugs?? Also does anyone out their have a stock d16a lieing around their house they are willing to sell i will pay up too 200 bucks let me know.
RedRacerCivic
09-30-2003, 05:38 PM
I could be as simple as the 4 O-rings that lie around the spark plug holes, if they are worn out or corroded, oil will seep through those O-rings.
gsf1200m
09-30-2003, 06:19 PM
I have the same problem with oil on my #4 spark plug.
I havent realy been motivated to fix it or anything, I probably should.
HONDABOND
09-30-2003, 06:26 PM
What do you need? I got a block, head, PM7 Pistons and rods, and a crank... If you use the old intake and exaust mani you could pretty much put it together (Bearings and whatnot would be needed)
4GZChatch
09-30-2003, 06:58 PM
I have a D16Z6 head that I'll sell for $200. That's vtec on ya. It needs milled, but it's in fine shape.
Also, if you change your valve cover gasket, you should quit getting that oil in your plugs. I would do it quick, cuz I've heard of it catching fire if you get a stray spark at the top of the plug... Plus, it's a really easy fix, only takes about 15 minutes...
4GZChatch
09-30-2003, 07:01 PM
Sorry, I misread, I thought you were asking for a head. I only have a block with a big hole in it. However, you could stick this one on the top of your current block...
