lighting question??
hadezangyl
12-04-2001, 08:51 PM
I noticed today that when you have your lights on and you turn on your turn indicator that the headlight corner lamp getting brighter. I was wondering if someone knew how to rewire it so that the two corner lamps are that bright whenever the lights are on. Its a simple thing but I think it would look better if those were bright all the time. some body please give input. thank you much!!!!
bsr1031
12-05-2001, 10:11 AM
An easy way to do this is to remove the corner bulb. You will notice two "nubs" on it, one will be higher than the other. Clip the higher one off with a nail clipper or anything else like that. Now reinsert the bulb into the socket backwards...the lower "nub" should be inserted into the slot that the higher one used to go in. There you go, nice bright corner lights!!
hadezangyl
12-05-2001, 11:18 PM
THANK YOU SIR!
MegaMax
12-06-2001, 07:12 PM
Go to The Org (http://www.maxima.org) and do a search on my posts under Northeast and i posted Pics of the bulbs what 'NUB' to cut off and what it looks like Pre and After the Mod....
Enjoy The Ride...
Enjoy The Ride...
