Winshield wipers
Newchevowner
09-23-2003, 11:53 AM
On my '94 silverado i have been having a problem with the winshield wipers. They only work half the time. if they aren't working and i hit the wiper motor while they are on they will start working. does anyone know a way to fix this inconvienience without replacing the motor.
crazybill5280
09-24-2003, 03:58 AM
Chevy has had a ton of problems with the wiper modules on these trucks. The module is easy to replace, three t15 torx screws and 1 electrical connector.
LastOne
09-25-2003, 03:19 PM
There is a recall out for this. I think it covers 94-97. I have a 98 that has the same problem but the folks at GM will not include it in the recall. Easy to replace. Check your dealer for recall info! :crying: :crying:
SoCal Truckin'
11-13-2003, 02:30 PM
Guys,
My Dad's '99 Chevy full-size van has wiper woes as well. The problem with his is that they only work on one speed setting - High! None of the intermediate, mist or delay settings work. It's quite a pain. Could the module be the cause here as well? How do I check it without replacing it?
Thanks for your help.
W
CDeBerry
06-24-2004, 07:02 PM
Driving home from work today it decided to pour, it figures that my wipers decided to not work. Has anyone found a recall? @Auto Zones web site they show recalls but nothing on this! Help!!
newwavepage
07-30-2004, 09:41 AM
I found recall information at this site. http://www.alldata.com/
SoCal Truckin'
07-30-2004, 10:53 AM
What is the TSB #? I could not find it on the web site posted above.
Thanks for your help,
W.
chevycat
07-30-2004, 10:55 PM
My '94 Silverado does the SAME thing.It is very frustrating.I am going to look into the recall thing.
chevycat
07-30-2004, 11:10 PM
W.
I found this info regarding the TSB #'s.
http://www.trustmymechanic.com/recall.html
90Haccord
07-31-2004, 03:40 AM
I have same problem, Also with this I have found that right after that my lights started to have electrical issues with parking/brake lights in the rear. Thought I found the problem with the aftermarket (U-Haul) trailer wiring. Then a few months it came back with an vengence. Now when the parking lights and/or head lights are on the rear brake lights(including the parking lights) dont work. Also noted that with the emergency lights on the lisence plate lights flash with the turn signals.
FUSTRATED!
Anyone got some ideas?
95silverado
07-31-2004, 07:33 AM
You can repair the wiper motor if you are good with a soldering iron. All you have to do is, unplug the wiper motor, take off the plastic cover, and resolder it where the plug contacts go thru the circuit board. It's a very easy fix. Fixed mine 4 years ago, and haven't had any problems. Good luck.
mike3028
07-31-2004, 08:50 AM
my 95 had the same problem. got tired of soldering and finally got the info for the recall and carried it to the dealer to get it fixed. the dealer can look up your vin # and see if it is included in the recall.
93_R/T_TT_Stealth
07-31-2004, 10:05 AM
Anyone know the part # for the wiper module on a 94 silverado 4x4 305ci......? got the same prob. the motors work but the module wont work..
thanks
93_R/T_TT_Stealth
08-01-2004, 12:54 AM
k guess not - thnx
