fuel odor
cclake
12-03-2001, 06:15 PM
Does anyone know if there was a recall for fuel leaks?
tonys
06-27-2002, 08:08 PM
try calling the 1-800 number for GM Canada, they will be able to give you more info.
I have a 99 sunfire and am all up to date with my recalls and have not heard of such.
kerrybro
01-17-2003, 09:23 PM
Based on other complaints i have heard from sunfire owners, it could be a loose injector or injector gasket causing the fuel to seep out around the injector in question.
See ya:finger:
Scott 02
02-04-2003, 08:57 PM
There probably will be a recall out soon. I have heard the complaints about a fuel leak on these newer Sunfires as well. Got to be bad injectors in these cars. Fuel Pumps have had no problems.
lillou1973
05-01-2005, 01:00 AM
athough i can only tell you because it happened to me too is that you might want to see if your fuel regulater is leaking....not too bad to fix
