Battery Light
rjvette23
09-14-2003, 09:35 AM
I started noticing my battery light is staying on very dimly. It doesn't seem to matter if the truck is on or off. Everything seems to be working normally. With the engine running, I have almost 14 volts on the guage. Any thoughts??
Thanks in advance....
2003 Silverado Base Model
2wd, Vortec V-6, automatic
Isaacson
01-04-2004, 12:20 AM
I have just a few questions regarding a 00 silverado fuel pump When it is verry cold it sounds like it is working hard almost a grinding. When I turn on the ignition the relay kicks in and shuts off normal. Only when I start it it is noisy and comes in and out. The truck idles great and runs out nice. Its just noisy.Any help would be great
Isaacson
01-04-2004, 12:22 AM
I filled my battery up with water because it was low and the light went off. Hope this helps.
