96 GSR idle sound
config
09-13-2003, 03:27 PM
I dunno, but my car seems to sound pretty crappy. Just looking for some AF imput
Belt (http://pages.sbcglobal.net/faction/belt.AVI)
Over Hood (http://pages.sbcglobal.net/faction/hood.AVI)
Inside Car (http://pages.sbcglobal.net/faction/in-car.AVI)
Revving (http://pages.sbcglobal.net/faction/rev.AVI)
Under Hood (http://pages.sbcglobal.net/faction/inside%20main.AVI)
Under Hood #2 (http://pages.sbcglobal.net/faction/inside.AVI)
Under Hood #3 (http://pages.sbcglobal.net/faction/inside1.AVI)
Under Hood #4 (http://pages.sbcglobal.net/faction/inside2.AVI)
tran_nsx
09-13-2003, 11:16 PM
none of ur sites or links came up. u should fix.
tran_nsx
09-13-2003, 11:27 PM
ok now it did, but it took a really long time. gotta be cause i have dial up, i would like to help if i can but im definately not gonna wait 5-15 mins for one down load, sorry.
config
09-14-2003, 12:11 AM
sorry they are videos.. there is nothing i can do about size. thanks though
blitzgsr97
09-14-2003, 04:33 PM
def sounds like a valve tap. how many miles is on you integra. they do sell lubrication for this type of problame. It quiets your valves .
98-integra
09-14-2003, 05:57 PM
does it seem like you have lost any power if so it might be a bad plug dont know just trying to help
config
09-14-2003, 07:15 PM
Its a 96 GSR with 74,000 miles. I dont know, my car seems kinda slower than before i noticed this, but im not sure
asauger
09-15-2003, 04:34 PM
Def check the plugs and wires. Is there any smoke?
92acuraattack
09-15-2003, 11:07 PM
sounds like your valves are loose and need adjustment
they can be adjusted to within spec by yourself if you got the tools its not hard at all. I would suggest getting a haynes automotive repair book or something similar because it goes through the steps on how to properly adjust the valve lash which is the clearance for your valves. If your valves are loose which they really sound like they are in the under the hood #2 then you would be loosing power as they are not opening up high(lift) enough and not for the right time period(duration)
the only tool you really would require is one that measures the clearance
of the valves which i think is a feeler guage or something similar
other than that there is a nut on top of each valve that you loosen then you tighten the screw in the center of the nut to within specs. Then tighten the nut back up. I really dont know all the specifics but this should help. If you are really lost then go to the acura dealer or a honda dealer because the adjustment is routine and they know what they are doing
config
09-16-2003, 12:23 AM
thanks for lengthy informative responces guys, how much does valve adjustment cost at acura dealership?
92acuraattack
09-16-2003, 05:18 PM
for the valve adjustment you will need to purchase a valve cover gasket so they will probably hit you up for that around 40-50 bucks and then the service might take an hour so whatever their going rate prob $65-75 for the first hour of labor i would just call a local dealer I got no real estimate though but good luck hope you get it all figured out :smokin:
