Help!! Motor Mount hangup!!
jackacc
09-12-2003, 08:11 AM
I am doing a Y8 swap but my friend who is installing it is having a problem with my timing belt side motor mount.
My car is a 91 STD and I am putting in a 97 Y8 motor. Can anyone let me know if there is anything that can be done?
Should I use the mount from my original motor? I think He was trying to use the one from the Y8.
Thanks!
Thanks!
CZ-R
09-12-2003, 08:30 AM
I haven't done the swap myself (yet!), however, in everything I've read about the proper procedure you're *supposed* to use the driver's side motor mount off of your original motor.
Where's Ami when we need her?? :crying:
dirty91crx
09-12-2003, 04:50 PM
i concur....use the 91 mount
jackacc
09-12-2003, 07:50 PM
cool, thanks!! will do...
dirty91crx
09-12-2003, 09:06 PM
ever tore the front motor mounts? might i suggest go to home depot....find a tube of concrete poly(kinda like caulking) when it dries it basicaly dries like a poly mount...but a little softer. so far mine has been going strong for some time....i say this as i have torn motor mount inserts and have since switched to this method.
