noob: engine swap
b16a
09-07-2003, 05:12 PM
does anybody know of a possible engine swap for a 1997 Accord LX that is cheaper than the H22A?
Thanks
Thanks
euroAccorDeuro
09-07-2003, 07:05 PM
Well the next step down would be in the b series, but u would actually probly have less power, and some more room in your engine bay. If your gonna do a swap do the h22.
93accordEX
09-07-2003, 07:08 PM
umm no b series is not even a consideration for accords. the next engines would be h23/jdm f22b with 160 hp dohc non-vtec.
b16a
09-07-2003, 11:27 PM
I see, whats the HP/torque of the H23 JDM?
FabuLaS|AccoRD|H22
09-08-2003, 01:03 AM
I have the H-22 in my accord, Iam honda lover and been around for a while. Iam positive that the H-22 is best option for the size of the car!
If you decide to go any other size, you will be upset that you made wrong choice. As far as B series, They just dont have the pull a h-22 does! Make sure you do your swap correctly and know it going in the right way, There is alot of custom things a h-22 need to fit and work right! If you are getting JDM motor make sure its real and make sure its not beat up!
MaK
09-13-2003, 01:33 AM
Only other option is a usdm H23, good torque (more important than HP) and you can still use your accord tranny.Plus they make lots of power with some head work.
darkaccord
09-13-2003, 09:48 AM
F22B1, the engine the EX has. I'm not sure how much more hp it is but its VTEC.
MaK
09-13-2003, 01:29 PM
It's 150hp and 160Tq
93accordEX
09-13-2003, 08:11 PM
wrong. its 145 hp and 147 lb/ft
MaK
09-14-2003, 02:38 AM
Whatever those are base min numbers, we have never engine dynoed one below 148hp/156.3tq mid you we have only done three.
wagsaccordsir
11-04-2003, 04:35 PM
So basically what you just said, is that after some head work on an H23 now you basically have an H22?
H23's have weaker bottom ends.
Yes an Accord tranny will work? But why? The gear ratio isnt the same nor is the torque rating.
Good torque? Ok maybe, but more important than horsepower? C'mon man, they work hand in hand, you can't have one without the other.
F22B1 (VTEC) stock is 145hp/147ftlbs just as 93AccordEX stated.
Why are you dynoing stock Accords? What sense does that make? Maybe 148hp with an intake.. LOL
Go with the H22 and don't look back!! If you need help or have questions hit me up!!
92lx
11-05-2003, 08:56 PM
H23 (160hp)....basically the only worthwhile swap for you is the H22.
- Nathan
- Nathan
