Fuel pump CRX 88 SI
1MYSTIKLXI
08-18-2003, 10:11 PM
How do you test to see if it's bad?
Also how in the world do you remove it from the tank? I got the rest of the stuff from over top of it but can't figure how to get it loose.
BullShifter
08-19-2003, 02:59 AM
With ignition off disconnect the Main Relay
Connect a jumper wire from the blk/yel to yel/blk
turn ignition & probe blk/yel+ / yel/blk -
If power - replace the fuel pump
No power - replace the main relay
Use a jumper wire from a positve source & connect to positve fuel pump for testing
Pry the fuel pump from the tank gently
