Need Info on 87 GTI
Bootleg
08-16-2003, 02:13 PM
Im seriosuly considering this car. One came up and i need to see it. I need info on what to look out for and general info on these cars. I have looked at some websites but none are that great. Any help would be appreciated.
Thank you
-Boot :screwy:
SolTheHoelessPimp
08-16-2003, 05:37 PM
1987 Volkswagen GTI 16V
2 Door
Hatchback
2WD
1.8L
Overview
Safety
Standard Features
Options
Technical Specs
Specifications & Dimensions
Manufacturer Code No Data
Wheelbase 97.3
Overall Length 158
Vehicle Height 55.7
Vehicle Width 65.5
Front Headroom N/R
Front Legroom N/R
Curb Weight 2,150
Gross Vehicle Weight N/R
Seating Capacity N/R
Payload Capacity N/R
Towing Capacity N/R
Final Assembly Location N/R
Brakes
Mfr. Code Description
Brakes, Power Disc/Drum Std
Drive
2 Wheel Front Drive Std
Engine
Engine, 1.8L 4 Cylinder 102 hp Gas
* Cylinder Number: 4
* Valves per Cylinder: 0
* Cylinder Configuration: In-line
* Compression Ratio: 0
* Camshaft: OHC
* Engine Size: 1.8
* Engine Type: Gas
* Coolant Capacity: 0
* Oil Capacity: 0
* Stroke: 0
* Bore: 0
* Horsepower: 102 @ 5250rpm
* Torque: 110 @ 3250rpm
* Fuel Capacity: 14.5
* Fuel Type: Unleaded Regular
* Fuel Delivery Type: Multi-Port Fuel Injection
* Fuel Delivery: Multi-Port Fuel Injection
Std
Transmission
Transmission, 5 Speed Manual OD
* Type: Manual
* Speeds: 5
* Overdrive: Y
* Gear Ratios:
1st Gear: 0 2nd Gear: 0
3rd Gear: 0
4th Gear: 0
5th Gear: 3.67
6th Gear: 0
Reverse: 0
Final Drive: 0
* Torquelock: N
* Heavy Duty: N
* Std Gross Vehicle Weight: 0
* Max Gross Vehicle Weight: 0
* Curb Weight: 2150
Std
