Help Ima Newbie!!
AFI 05
08-13-2003, 01:22 PM
Hello, I just bought this ITR and umm I bought a can of Testors Flat Red and I changed my mind on the color as u can see...:confused: well, I'm going to rely on you guys' help so I can accomplish a kick-ass model and I wont be discouraged and drop my new hobby :iceslolan well thaks a lot!
AFI 05
08-13-2003, 01:25 PM
So now what do I do? Do I just do the primer and start the painting process....?
AFI 05
08-13-2003, 01:27 PM
one last pic...
DJ RaYgU
Hi! Welcome to AF! :D
So wut do u need help with?
DJ RaYgU
08-13-2003, 01:29 PM
What exactly have u done so far? As far as I can tell, u sprayed with red. Then, u removed it because u changed ur mind.
EMAXX
Hi, and welcome. I think you might want to try and stip the body down a little more before you primer, then paint it.:bigthumb:
DJ RaYgU
08-13-2003, 01:30 PM
And oh yea, read the FAQ first!
AFI 05
08-13-2003, 01:34 PM
yeah umm I changed my mind from the red and now I need like some help on if i should strip it more? Or just apply the primer over it.. Yeah i read the FAQ already thanks.. :tongue: so umm I'm thinking of either doing it black or another, shiny red cause I had no idea what flat red would look like.. lol
EMAXX
08-13-2003, 01:38 PM
I think you should strip it a little bit more, like I said in my previous post.
AFI 05
08-13-2003, 01:40 PM
oh hehe thanks... What paint do you recommend for a glossy red finish?
DJ RaYgU
08-13-2003, 01:41 PM
U might wanna strip it down some more using brake fluid or that Castrol super cleaner stuff. BTW, wut did u use to strip it down? After u've removed the red, go ahead and prime it. Refer to PMAN's priming and painting FAQ. Good luck.
EMAXX
08-13-2003, 01:42 PM
I really Tamiya paints, but the closest hobby shop to me is like 8 hours away, so I'm stuck using Testors, but if you can, use Tamiya.
DJ RaYgU
08-13-2003, 01:43 PM
Use a Tamiya color spray.
AFI 05
08-13-2003, 01:44 PM
Well uhh I removed it with brake fluid and a wire sponge.. well i might sound like a dumbass.. but im new.. and whats BTW? LOL well thank you.
EMAXX
08-13-2003, 01:47 PM
by the way
AFI 05
08-13-2003, 01:48 PM
Hmm Tamiya ey. I hope I can find some. Thers a "Hobby People" store around here I'm sure they will have some.. ohh also.. were can I get the rubbing compound? Like at Pep Boys or Auto Zone or sumthing..
DJ RaYgU
BTW is an acronym for "by the way"
IMO is an acronym for "in my opinion"
Yea, it took me a while to figure that out too:biggrin2:
anyways, try to remove the rest of the paint. Dip ur model in brakebluid for a few hours and that might do the job.
EMAXX
08-13-2003, 01:51 PM
Yep, get the paint at a hobby store, and rubbing compound at most automovtie stores.
AFI 05
08-13-2003, 01:53 PM
LOL yeah :loser: well so Ima finish taking the paint off and then I'll go buy some primer and ill stop at hobby people to get the paint.. all i need now is buy the compound.
AFI 05
08-13-2003, 01:54 PM
Any idea how much the lil tube of compound stuff costs? :comprage1
DJ RaYgU
08-13-2003, 01:58 PM
WHat!?? Automotive stores sell rubbing compound? I never knew that! That means I dun have to use friggin toothpaste anymore! :biggrin:
DJ RaYgU
08-13-2003, 02:01 PM
I have no idea, as I use toothpaste for rubbing compound:biggrin:
Use Tamiya spray paint for the exterior and Testors enamel for the engine and interior, but u can spray the interior for even better results.
AFI 05
08-13-2003, 02:12 PM
oh well uhh I already did the interior and the engine and EVERYTHING i just need the body. TOOTHPASTE!?! does it really work? LOL:iceslolan
Tommy Gunner
08-13-2003, 02:14 PM
Just so you know flat paint doesnt shine. Gloss or mettalic(sp?) is the kind you want for exteriors. You could use the flat red for the interior and maybe the engine.
AFI 05
08-13-2003, 02:18 PM
yeah lol I had to learn that the hard way... It was all dull and stuff so thats why I removed it
AFI 05
08-13-2003, 02:21 PM
So.. DJ Ray.... is toothpaste a good working alternative? what is the outcome on the paint? any pics..
Tommy Gunner
08-13-2003, 02:22 PM
and one more thing is that you HAVE to use clear coat on mettalic colors (I don't know why you could ask another guy why) on other exterior colors its optional.
DJ RaYgU
08-15-2003, 01:49 PM
Toothpaste is cheap and of course its not as good as the real stuff, but it does a fair job at polishing, although it takes a very LONG time. Sometimes, toothpaste can even dull out the paint even more, i dunno why. Here's a good compounding tutorial: http://www.interlog.com/~ask/scale/tips/rub/rub.htm
DJ RaYgU
08-15-2003, 01:53 PM
And oh yea, from my past experience, Colgate toothpaste seems to dull out Tamiya Black (TS-14).
integra818
08-16-2003, 12:08 AM
EMAXX
08-16-2003, 09:40 AM
Why would you use toothpaste? Thats the funniest thing I've heard. I'm going to try that to see if it really works. :lol2:
Diesel2NR
08-16-2003, 11:39 AM
Toothpaste is more abrasive than regular polishes I beleive (never used it), which might be the reason it dulls some paint. I've heard of it being used on primer to smooth it, but still give it enough tooth for the color coat to grab hold of.
Use a Clear Coat over Metallics! First, it brings out the true color and depth of the metallic paints. It also protects it when you go to polish and wax.
Good luck, and welcome to the hobby. :wave:
Edit: The info above about the toothpaste was told to me by another member here some months ago. He also noted that the all white toothpaste is what you want. The old style stuff. The gels don't get the job done.
