Code 8?
91civichatch2571
08-10-2003, 04:42 PM
My ZC is throwing a code 8. I know it means Top Dead Center position but what do I do about it? Does it mean that sensor is bad or something?
BullShifter
08-10-2003, 05:05 PM
First reset ECU then start engine & check for re-code. If light does not come on then your good. Start by checking ALL connections/clips. Distributor or TDC sensor could be bad.
crxlvr
08-10-2003, 05:13 PM
check your timing also.
91civichatch2571
08-10-2003, 07:23 PM
reset it and it returns. Im leaning towards my timing being off as crxlvr said.
BullShifter
08-10-2003, 08:47 PM
It would be nice for you if it was just the timing. I'm leaning towards dizzy replacement!
crx hf
08-10-2003, 10:20 PM
Im getting a code 12 (exhaust gas resirculation system) how do you fix that.
BullShifter
08-10-2003, 10:32 PM
1st reset ECU & check for re-code
Mostly likely the EGR system has a problem if code 12.
It could be loose connection(S)
Cracked hose
EGR valve
EGR solenoid valve
CVC valve
ECU
Im guessing its the egr valve - damn CA emmisions!
If you have access to a vacuum pump gauge, you could test the egr valve. Warm engine then disconnect egr valve hose. Connect vacuum pump to egr valve & apply vacuum. If the engine stalls or fails to hold vacuum, then its for sure the EGR valve
crx hf
08-10-2003, 10:34 PM
Wheres the EGR VALVE located?
91civichatch2571
08-10-2003, 10:35 PM
I'd be really pissed if I had to replace the dizzy because I just got the one thats in there (its used though) and it cost me almost $100. 88/89 integra dizzy's are suprisingly hard to find.
BullShifter
08-10-2003, 10:50 PM
Near the intake side of #4 cylinder(closest to distrib.)
