Squeaky Honda Civic Breaks
AMP
08-06-2003, 02:12 PM
My 99 Honda Civic brakes (with 40K miles) just recently started to squeak - only when I brake softly, not at a hard brake. Also, on a soft brake, they sqeak during the first half of the "braking process" and not toward the end. What could be potential causes?
Thanks for the help!
project92si
08-06-2003, 06:14 PM
dust could be the problem...shoot it out with the hose....if not then maybe ur rotars need resurfacing but i doubt it cuz you only got 40,000 miles on it. if the hose no work take the break pad out and sand it down a little...dont forget to wipe it clean...laters
csaddict
08-06-2003, 06:39 PM
The problem with 90% of all brake squeeks is the piston rubbing against the back of the pad. Put some duct tape on the back of the pad and it WILL stop squeeking. I know you think that is wierd but it works and I managed an Auto Parts store for 5 years and have cured this problem many times.
BullShifter
08-06-2003, 09:53 PM
Most likely the BRAKE pads are worn. Brakes should also be clean/adjusted/lubed atleast every 15k for Hondas. You should use Molykote on the pad shims & back of pads, not duct tape:iceslolan
J_nieves
08-07-2003, 12:18 AM
i had the same problem i went to an autozone and i bought a packet of brake noise stopper sorry i dont remember the name but its pretty cheap but it works i use it ebery time i replace my brakes
