installing neons to switch
frozen_Joth
07-29-2003, 09:12 PM
I got 2 15 in. neon tubes of this guy I know. he gave me a switch with them but I don't how to wire this sh*t up, The switch only has two tabs, how do I run a power source to it along with my neons and then ground it? Do I run one wire from the switch to the battery and connect the power wires from the neons into that and use the other tab on the switch to ground it? I don't have a clue and I can't ask the guy cuz' he went on vaction. Any help is appreciated! thanks.
EFStali
07-29-2003, 10:22 PM
dude, do a search there is a thread thats about 6 pages long. 1phatcivic i think made it.
ci5ic
07-29-2003, 10:49 PM
Here it is... starts on page four to page six... just read through.
http://www.automotiveforums.com/vbulletin/t97764-4.html
phatmitsu
07-29-2003, 10:51 PM
Well there is two ways to do it.. You have a non lighted switch hence only two prongs.. The ones with three are the switches that light up.. Anyways you can hook a wire from power source(preferably a fused one) to the switch and then to the neon or you can hook the neon directly to power(use a fused source or inline fuse close to power supply) and hook the switch on the ground side or the circuit.. ONCE AGAIN I CAN NOT STRESS IT ENOUGH MAKE SURE IT IS FUSED AS CLOSE AS POSSABLE TO THE POWER SOURCE... Ive seen many a cars go up in flames due to shitty wiring.. In my truck i had a inline fuse on 8 gauge wire going to aux fuse panels that then powered all my neon.. Trust me its more work but worth it.. later Rick S
1PhatCX
07-29-2003, 11:11 PM
Originally posted by EFStali
dude, do a search there is a thread thats about 6 pages long. 1PhatCX i think made it.
:biggrin: :bigthumb:
EFStali
07-29-2003, 11:14 PM
ha ha..yea dumb on me :biggrin:
hell i dont even have my neons anymore, they all broke
1PhatCX
07-29-2003, 11:18 PM
lol, mine r still good! :) they work awesome, i wanna get a few more but i'm strapped for cash!! :frown:
frozen_Joth
07-30-2003, 07:45 AM
o.k. thanks but i dont have a transformer for my neons, how much of a problem will that cause? Can I still hook them up to the switch? Damn this is causing me more trouble than I need:rolleyes: . help!
frozen_Joth
07-30-2003, 03:07 PM
anybody?:dunno:
frozen_Joth
07-30-2003, 09:01 PM
c'mon I'm gonna cry :crying: j/k
1PhatCX
07-31-2003, 01:50 PM
yes u can still hook em up
connect the positives of all the neons to one prong on the switch, then ground them all to a spot on the body, then with the other prong, run a wire from that to ur fuse box... its not hard
frozen_Joth
08-02-2003, 01:28 PM
i dont have to ground the switch?
frozen_Joth
08-02-2003, 03:37 PM
o.k. I hooked all my power wires to one tab on the switch and grounded the neons. I hooked up a wire to the other tab and ran it to one end of a fuse and hooked a wire from the other end of the fuse to an empty slot in the fuse box. I went to turn the switch on and nothing happened. I stuck the spade connector in the other slot in the fuse box and still nothing. What did I do wrong????
1PhatCX
08-02-2003, 06:09 PM
its one or all of these things...
one, not grounded properly
2, use a fuse and not the spade connector
3, the lights might take a little while to turn on, i've noticed mine do once and awhile now
4, that fuse slot doesnt work maybe? i dunno
just a few ideas i thought about
frozen_Joth
08-02-2003, 07:17 PM
I wrapped the wire around the fuse and stuck it in and it works perfect! thanks alot man!:bigthumb:
1PhatCX
08-02-2003, 10:59 PM
no prob dude, glad 2 help
NismoBoi34
03-27-2004, 10:05 PM
y do u need to use a fuse?? neon lights don't use that much power. I'm thinkin' about using a cigarette light adapter and a switch. The cigarette adapter has 2 wires comming out of the end. I need to take both of those wires and tape it to the 2 prongs of the switch right? then take the two wires from the neon and tape it to the 2 prongs? is that how u do it?
JimCRX
03-27-2004, 10:25 PM
I was gonna say the way I have mine. I ran a wire from the remote amp wire to the power source with my neons, connected a power wire to my access. power wire on my head unit harness and connected the ground to the ground wire on the harness. Worked just fine. I also got my amped wired to switch on/off.
TeamDraZtiK
03-27-2004, 11:09 PM
who cares... neons and lighting shit is all riced out gay shit.
