read engine codes?
scott_krehbiel
07-27-2003, 04:47 PM
Anybody know how to trigger the Cavalier
to give you the engine codes?
I once had a '81 Firebird that would often junk
out its oxygen sensors and have associated probs.
I took it to a friend who was a mechanic, and
instead of hooking it up to a computer to read
the engine code, he just stuck a piece of metal
between two contacts in the "computer" plug.
Then he watched as the Check Engine Light
blinked out the numeric codes. (oxygen sensor
and mixture too rich) :cool:
I'm in a cruch, because I'm supposed to leave
on a 7-hour road trip thru the desert out here
in CA and I need to leave by mid-day tomorrow.
So any trick to let me know ahead of time
whether it's a serious problem or not would
be really helpful.
Thanks
Scott
pcv
07-27-2003, 05:15 PM
Unfortunately, on new vehicles (1996 and up) now you have to scan the system using and OBDII compatible scanner. The old system was convenient. Not so anymore. You can take it to a garage to get it scanned. Leaving the gas cap loose will set a code. It could be as simple as that. Get it scanned. Good Luck.
