What size swaybar?
michaelsd16c
07-25-2003, 01:53 AM
What up fellas
I wanted to know what size rear swaybar I could get for my 94civic and no it didn't come with a factory rear sway. The front sway is a 21.mm I also want to know if their would be a problem to get 24.mm front sway. I am looking to get a ITR 22.mm rear sway. If it helps I have a full cat-back Apex=i N1 exhuast system. The reason I say that because I herd that getting any sway for the rear could be a problem with aftermarket exhaust system. And I thanks I know about he beaks kit.....Thks Y2k
SilverY2KCivic
07-25-2003, 02:19 AM
Like I had mentioned to you, those bars should be fine. The 24mm up front will definitely be fine since it's not much of an increase. The rear, contact Beak's and ask about how you'd install it. You might need to have a hole drilled into each of your rear lower control arms for the endlink bolts to go through. As for the exhaust clearance, I have an A'PEXi World Sport exhaust, which uses the same diameter piping as your N1 uses between the cat and the muffler itself, here's what the passenger side of my suspension looks like, note the paint scraped off the exhaust piping just above the upper bolt of the endlink... That's about now much clearance there is, and it WILL rub on the exhaust when that corner of the car's suspension is fully compressed such as angling up ramps, especially if lowered like my car is...
SilverY2KCivic
07-25-2003, 02:42 AM
Another pic of how my rear suspension setup is so you can better see the ITR bar in place. Remember it'll be different with your car since your's is a 5th generation style Civic...
michaelsd16c
07-25-2003, 06:23 PM
Ok I see, nice pictures. Bare with me. I talk to this guys who has a lot of experince in race(really). He told me that the best way to go is by stiffing the springs in the back, like to about 480lb anything higher would make it way to stiff. That it would be easy since I have GC. Do you agree??
One more thing my lower rear sub-frame is a little bent. Do you where the bolt conect to the lower arms? Well after the bolts it's bent to the right.Example put your hands together but leave a space in between. Now bend only your finger tips to the right. Thats what my sub-frame looks like. So would it be a good idea to get sways? Wouldn't the beaks kit reanforce the bent frame. Since it will sandwich the subframe togther?
