sway bar specs
michaelsd16c
07-21-2003, 08:35 PM
Anybody no the sway bar specs on a integra ls? Which Model has better
sway bars? LS or GSR??????
Hey whats better to have a bigger mm sway in the front or in the back?
I surffing on the web and I found that a gsr has sway bars of 24.0mm front and 14.0 in the back is this right? Some one told me that it is better to have a bigger size in the back because too big a size on the front the car wont want to take the turn. (understeer) I think????
michaelsd16c
07-22-2003, 01:18 AM
Come guys nobody knows the answer ........Theirs got to be somebody that knows right?? ????
SilverY2KCivic
07-22-2003, 02:47 AM
Too big in the front will cause more understeer than normal which is when your car wants to keep going straight when you turn. A bigger bar in the rear will cause the balance of the car to become more responsive and allow the rear to react better to things. Too big of a rear is bad though because it's prone to snap oversteer which is when the rear end unexpectedly snaps out from behind you whin in a turn, which will cause you to spinout without any control whatsoever to stop the spin. Results of that can be costly, and even deadly.
Oh, and GSR bars should be bigger than LS. Remember as you go to a better trim level model, parts will always be bigger and better.
