idol thats funny
stang-a-tang
07-18-2003, 08:45 AM
ok when i go to the gas station and fuel up my car it will stall out every time i try and start it and even other times it just dies out can someone tell me what is wrong and what i should do. i already cleaned out the throttle body but that didnt seem to work. could it be the idol sensor. idk someone help.
Tony H
07-18-2003, 08:49 AM
No real help but its idle.
76_cobra
07-18-2003, 12:18 PM
Maybe your fuel filter needs to be replaced it could have alot of gunk in it my car kept stalling intermittently and I replaced the fuel filter, which was way old and the car ran fine after that.
BigDanTheMan
07-18-2003, 01:16 PM
i agree with the fule filter diagnosis mentioned above. it's a good place to start at least and you can check in yourself with ease
Unit 5302
07-19-2003, 11:55 AM
Check the EGR valve to make sure it's not stuck. Also, you say it just dies every time it wants to idle?
stang-a-tang
08-08-2003, 06:32 PM
ok i just put in a new tank and changed the filter and everything all at that time but i will change it again cause thats not a big deal.
also i advanced the timing cuse it was off just a little and now it doesnt do it as much
whats a egr valve?? cause i'll do that once i kno what it is. the car will rev all on its own for like a minute when i first strat it. and it goes down to almost 0 and then shoots up to a grand. but only after fueling.....................
