About to buy a 2003 Xterra SE-SC 5speed...
Santino
07-16-2003, 10:39 PM
What are somethings that i should look out for, for example: problems, annoyances etc etc....
Thanks
Santino
07-16-2003, 10:42 PM
another quick question....
is there a model change for the 2004 Xterra?
ChuckH
07-16-2003, 10:57 PM
Nothing major to watch for.
Changes for 2004 are a couple new colors and that's about it. 2005 brings the major changes when t e Xterra moves to a new frame and is completely redesigned and engineered.
Santino
07-16-2003, 11:07 PM
Ok thank you, its just the last two vehicles we bought brand new, early 90s corolla and 96 maxima they changed the model the following year. I didnt wanna get screwed again
Thanks again
What are some problems that people are experiencing with the 03 X
Thanks
OffroadX
07-17-2003, 08:53 AM
No problems with the 03 really, though some take issue with a change in the way the A/C behaves. If you select any defrost mode, the compressor kicks in (nothing new) but it now does not shut off when you select a non-defrost setting until you actually shut down the engine. Big whoop if you ask me.
FYI, unless you're in Canada, you can't get a supercharged 5-speed.
Brent
Santino
07-17-2003, 12:41 PM
Thanks for the heads up about the A/C
And yes i am in Toronto Canada.
Why is it that only canadian Xterras are available SC 5speed?
ChuckH
07-17-2003, 10:41 PM
Manual transmissions don't sell in the U.S. anymore because we're a country full of lazy asses, so the manufacturers are basically saying "only 10 % of you want the manual transmissions so screw you!" We can't even get the regular SE with the manual; only the XE. The funny thing in that is that for Nissan the SE designation has always been for the sporty models. XE was base, LE was luxery, and SE is sport. So, they took away the only thing that was even remotely sporty about the Xterra. They should relable it as an LE model...ugh! :(
I most likely won't buy another one unless Nissan brings back the manual transmission. We'll see what 2005 brings us besides a 5 speed auto "not so" magic.
Alay510
07-20-2003, 11:25 PM
why does everyone want an se so bad. it doesn't come with anything that spectacular (except the OPTION of paying extra for the supercharger). anything else the se has can be added to an xe (with manual) for cheaper aftermarket, and most likely better.
so unless you really want the supercharger, it's better of getting an xe with that much desired 5-speed and get all the other bells and whistles later.
Santino
07-20-2003, 11:37 PM
you have a point, but the way i see it is that I or my dad i should say, since he is the one buying it, most likely wont have the time nor will he put the effort into getting an aftermarket supercharger and whatever else comes extra on the SE, therefore he spends the extra cash and gets everything from the dealer and saves himself time
To each his own.
