2002 Blazer rear end squeak
mkuhn
07-16-2003, 03:58 PM
I am having a irrating problem with my blazer, and I am wondering if anyone else has experienced the same. Everytime I go over a bump even the small ones there is a high pitch squeak coming from the rear end, I took it to the dealer and they proceeded to tell me it was the emergency brake cable going through a cut out and they put grease on it, guess what it didnt work. I also have a creak in the rear leaf springs seperate from the other squeak. Are these common problems and what has anyone done to fix them if they have had the same probs. Any help would be appreciated. Thanks
Mike
Mike
Drewbu
07-21-2003, 11:52 AM
i have the same on mine 98 blazer ...
I actually have squeak comin from tail gate na hatch back ..
try to open it hatch and tail gate ... slam tail gate and then close hatch ... this helps...
The other thing i noticed .. if you have tire inside, the metall bar has some kind of cution on it .. it seems to move and the tire rubs aganst the bar ... try removing tire and put it back on. (may be put new piece of clothe on it)
hope it helped
hope it helped
Linger1974
11-21-2003, 08:29 AM
My Jimmy has a squeak in the rear seat hinge. Kind of annoying too, but W/D is the cure.
