Shes Alive!!!!!!!!!!!!! but...............
walt0023
07-13-2003, 12:08 PM
well i got her started, oil looks like a milk shake but its running. carbon all over the plugs. its shooting out a 3 and 9 code, now i know whhat a 9 is but WTF is 3? manifold absolute pressure is what???
Kunundrum
07-13-2003, 12:34 PM
that's one of the sensors on your manifold, Probably bad due to the water in the intake... try replacing it.
SiZ
07-13-2003, 01:06 PM
MAP sensor.
Marc-OS
07-13-2003, 01:56 PM
I would suggest an oil change before anything, running your car with crap oil is gonna hurt it. Shouldn't be too surprised about the MAP sensor, considering your intake manifold was probably flooded with water. It was probably impossible to not break the MAP senson. Probably need a new one, and they aren't cheap from what I've seen.
walt0023
07-13-2003, 02:15 PM
i have changed the oil twice so far.
walt0023
07-13-2003, 02:18 PM
where can i order a MAP sendor from and how much do they run?
walt0023
07-13-2003, 02:47 PM
would my MAP sensor going cause my computer to throw a code 9??
SiZ
07-13-2003, 03:52 PM
I thought code 9 was something to do with your distributer.. I think thats what mine was throwing when I had to replace the dizzy.
Just off the top of my head I thought that code had something to do with that.
EDIT:
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Thats the one I had when my distributer seized and fell apart on itself..
Code 3 or 5 Manifold absolute pressure
MAP sensor. Good luck finding one.. Try one off a D16A or something!? :confused:
EDIT2:
Where is my MAP:
http://www.honda-tech.com/zerothread?id=426313
Where to get a MAP sensor from:
http://www.honda-tech.com/zerothread?id=365487
http://www.honda-tech.com/zerothread?id=58294
Code 9:
http://www.honda-tech.com/zerothread?id=165375
http://www.honda-tech.com/zerothread?id=81536
I'm bored and you're welcome. :sly:
GTA
07-13-2003, 04:05 PM
i see map sensors on ebay all the time search for honda map
mellowboy
07-13-2003, 04:47 PM
I see map sensors everywhere in the junkyard!
EF You
07-13-2003, 09:19 PM
get one off of a 90-91 integra
