sunfire inner door panels
freezer12
07-12-2003, 06:37 PM
hello j-body owners,
anyone know how to remove the inner door panels on a 99 sunfire gt. the screws have all been removed but the panel seems to be stuck on the window handle. any help would be greatly appreciated.
todd
[email protected]
sunfireguy
09-17-2003, 02:50 AM
The area right above the door handle there is a small panel that you need to snap out. Once that is out, use a screw driver (and a rag around the screw driver to keep from scratching the paint) to pop off all of the clips holding the door panel to the door (Use the screw driver :) I made the mistake of just pulling all of them off using just my hands, broke one of the clip brackets off of the door :shakehead ). Once all clips are loose, you can now pull the lower part of the door panel out and lift up and out comes your door. You may also have to unplug some wires depending on your accessories.
