ITR Muffler
DJ RaYgU
07-09-2003, 05:17 PM
How should I mount a muffler on my Revell ITR?
Hiroboy
07-09-2003, 05:19 PM
With glue!
This post should be in the general section I think.
07-09-2003, 05:21 PM
Originally posted by Hiroboy
With glue!
This post should be in the general section I think. I agree!:smile:
MR-2RaCeR
07-09-2003, 08:36 PM
:iagree:
DJ RaYgU
07-09-2003, 08:44 PM
No, I mean like, which parts of the original exhaust do i take off and stuff, you get the point rite?
fullbloodchop01
do u just mean the actucal muffler or the tip?
DJ RaYgU
07-09-2003, 08:48 PM
Holy crap! I post something and two seconds later someone replies. I love this place! I mean the actual muffler with the tip on it.
fullbloodchop01
07-09-2003, 09:17 PM
dont need to remove anything
first put the first half of the exhaust that connects to the header, glue it in, then glue the other part of the exhaust, the ppart that has the muffler attached.
HTH
DJ RaYgU
07-09-2003, 09:40 PM
:comprage1
No! I mean, how do i mount the muffler onto the other end of the exhaust. I know how to mount the exhuast to the chassis, but dont know how i should mount the muffler onto the exhuast system.
B16EF
07-09-2003, 09:47 PM
:confused: Look at the instructions:smile:
fullbloodchop01
07-09-2003, 10:01 PM
um the muffler is already attached to the piping, so all u need to do its atach that to the chasis
DJ RaYgU
07-09-2003, 10:34 PM
I'm going to use a scratch built one. I need to know how to attach it to the piping!:comprage1
Diesel2NR
07-09-2003, 11:34 PM
well, it depends on the tailpipe side of the muffler....personally, on the ones I'm making, I'm using a bunch of different tubing sizes so that the mufflers will fit onto 3/32" tubing.
fullbloodchop01
07-10-2003, 12:40 AM
ohhh i didnt know u meant scratchbuilt, you should have said that:tongue: well i say get some clay or putty or sumething, fill up the end of the muffler with it, and stick the piping in. might work, might not
DJ RaYgU
07-10-2003, 01:05 AM
Is this the right setup for a muffler exhuast system?
TheSyndicate
07-10-2003, 01:14 AM
Yep. I hope that's not how yours is setup because 90 degree bends in an exhaust system is just dumb. :rolleyes:
Diesel2NR
07-10-2003, 01:39 AM
Personally, I think you could've put that a little better. You should start trying to take the feelings of other members into consideration.
DJ, I think what he was trying to say is that on a 1:1 car, 90 degree bends like that would disrupt the flow of gasses through the exhaust pipes, and therefore not be practical. If you were thinking on doing a custom made pipe all the way to the headers, I'd suggest following the course of the stock pipe. Just my opinion.
As for attaching the tips, you could fill in the header side of the muffler with clay or something like that. THen I'd drill a hole in the clay after it's dry and then paint it. Then I'd superglue it in place. Hope this helps, and good luck!!:bigthumb:
B16EF
07-10-2003, 02:23 AM
:lol: Are you serious???
dumb is dumb is dumb and a 90 degree angle in an exhaust is dumb...1:1 or whatever
and, DJ RaYgU, either explain what the f*ck you're talkin about or DO IT YOURSELF.
BTW good luck with the build and be sure to post pics:smile: (and a nice close-up of your exhaust.):iceslolan
DJ RaYgU
07-10-2003, 07:20 PM
The pic was just a crappy rough sketch done in 30 seconds. WHy would i want a 90 degree angle in my piping? thanx forthe help tho.
