Are there better injectors then RC Eng?
mrchaos
07-09-2003, 03:18 PM
just what it says?
somedude
07-28-2003, 11:30 PM
rc engineering fuel injectors are themost popular injectors on the market todate and one of the most expensive i suggest buying the rc's off of ebay.
integragsr98
07-30-2003, 09:07 AM
Get some DSM 450cc injectors off eclipse...they works good and cheap! :bigthumb:
94tegRS
07-30-2003, 06:35 PM
ok, do the DSM ones bolt right in? anyone have accel injectors, 310CC are 47.95 each, dont know how much RC's are though.
civicgsr_T4_60-1
07-31-2003, 12:27 PM
delphi injectors work good for me, i have 880cc.
Saki0
07-31-2003, 01:07 PM
880cc...yikes! Are these in a racecar or street car?:smile:
civicgsr_T4_60-1
07-31-2003, 02:05 PM
this is in a daily driven street car.
http://www.imagestation.com/picture/sraid69/p44763bc7fac905cc98bc30ae020412d7/fbacc647.jpg
94tegRS
08-01-2003, 03:16 PM
WHOA, what do you have under there to need that big of an injector? what you run in that civic.
civicgsr_T4_60-1
08-01-2003, 03:22 PM
built gsr block, stock head, t4 60-1. That's it. Made 500whp and 360ft lbs. on lets say medium boost.
94tegRS
08-01-2003, 03:31 PM
wow, would the engine handle lets say hihg boost:biggrin:
I was planning on building a all motor CRVTEC but wouldnt get close that much power, now your makin me think about FI.
have you ever taken it to the track. all I really wanna do is break the into the 12's. I was a turbo LSVTEC run an 11.4 at pacific raceways but was hoping with more displacement and fully built I could at least hit a 12.99
civicgsr_T4_60-1
08-01-2003, 04:17 PM
on high boost and a semi stock head, i hope to make 600+whp and 400ft lbs. I've been to the track, but unfortunately have never gotten a clean run. Consistantly 11.40's, 11.50's. But i'm shuting down around the 800' mark and coasting it. There is a vtec oil pressure or vtec switch code being thrown. Once i get back to the dyno i plan on having that fixed. Mid to low 10's should not be a problem.
Saki0
08-01-2003, 05:39 PM
Nice ride! Keep it up!:bigthumb:
SleeperCivic
08-01-2003, 06:39 PM
BACK TO THE THREAD - before your thread got hijacked, I was going to say NO, they don't "bolt" right in. You have to swap gaskets here and there, wire some resisitors inline with the injectors or get an older resistor pack off a CRX. A lot of people sell them on forums like this one.
I bought RC's because they do fit right in. If you're running an OBD-I harness, you don't have to swap the injector clips. I also didn't want to have to worry about buying used injectors from some dingbat on Ebay.
megotgsr
08-02-2003, 12:16 AM
rc used fuel injectors are like 30 bucks a piece
S13GTR
08-03-2003, 04:09 AM
injectors are injectors but size does matter
