Adjust parking brake?
darkaccord
07-09-2003, 09:48 AM
I've noticed my parking brake is starting to slip on steep hills. How would I make the brake hold tighter?
BullShifter
07-10-2003, 01:23 AM
Rear brakes could be worn
or an adjustment
You need to access an adjusting behind the e-brake lever.
1. Raise rear tires off ground
2. Pull parking brake up 1 ONE notch
3. Tighten adjusting nut until there is slight drag on the rear tires
proper adjustment -- rear brake fully engaged @ 6-10 clicks
or an adjustment
accordztech
07-10-2003, 09:30 PM
my brake is i believe 4-7 clicks...though anything works.
