55w H3
DCastillo
11-16-2001, 05:27 AM
I really wanna put them in but i dont wanna fuck anything up. Is there anyway I can put in a fuse that can handle more electricity.. help any electrician!
Swonder67
11-16-2001, 06:32 AM
your stock bulbs are 35 Watts. If you put 55 watts in them, it will be ok. you don't need a higher fuse. However, you CANNOT go higher than 55 watt. Well, you can, but I don't recomend it. Yeah, most people on this forum switched their fog bulbs to 55 watt, so you should be ok.
DCastillo
11-16-2001, 02:00 PM
i know it "should" be okay, but I was wondering if theres anything I can do to make it 100% safe.
Swonder67
11-16-2001, 02:43 PM
well, everyone here who has done it says they are fine. I've even put in 85 watts in a P10, and they are fine If you want to do it 100% safe, you'd need new receptors, and you could get some bigger gauge wiring. but that's a pain in the ass. 55 wtt bulbs will be fine.
DCastillo
11-16-2001, 02:53 PM
ditto :-)
ViEt-G20
11-16-2001, 05:48 PM
u can get an upgraded harness.. they have them at most local shops
kenchan
11-16-2001, 09:01 PM
you can also get a relay and wire your fog directly to the battery with a larger wire...but its a pain to wire through the bumper, I would assume.
im using 55w piaas on my fogs...so far no problems.
atomic-G
11-16-2001, 10:23 PM
What are good bulbs to get for my fogs? I have Xenon Plasma's in there now. I have PIAA H4 Hyperwhites on my heads and want something similar, if not better. Price is not really an issue. Thx.
Swonder67
11-16-2001, 10:36 PM
Well, if price is not an issue, and you want better lighting, why not spring for an HID kit. You could get a good kit for $300 now.
A380Driver
11-17-2001, 05:27 AM
Woa woa...wait a minute...the G20's foglights ARE 55w stock.
Swonder67
11-17-2001, 06:50 AM
No, they G20 fogs are 35 watt stock I believe.
frogg
11-17-2001, 12:45 PM
Mine actually say, on the plastic peice, "55w"
I'll look again later just to make sure
kenchan
11-18-2001, 02:42 PM
yep, 55w stock.
