Eliminate Power Steering?
98Z
05-08-2019, 07:49 AM
Could a guy eliminate the power steering pump on a '97 with a 5.7 vortec? Mine is howling and I can't get it fixed for a couple more weeks. Is there a shorter serpentine belt to bypass the power steering pump?
Tech II
05-08-2019, 11:14 AM
Level ok?
Are there air bubbles in the reservoir of the pump(gives it a milky appearance)?
Are you losing fluid?
I wouldn't try it.....it is dangerous to drive, at low speeds, if you have to make an evasive move.....
Schurkey
05-09-2019, 11:50 PM
Be prepared to ruin the steering gear by operating it without lube.
OTOH, if the "howling" pump is tossing debris into the fluid, the steering gear is already shot.
When you do the repairs, be sure to install a PS filter in the return hose.
Tech II
05-10-2019, 05:56 AM
Shurkey, I have never heard of putting a filter on the return line.....
However, when replacing the pump, he should replace all the fluid in the system....by plugging return inlet in reservoir, and having the return line open ended into a container, and by filling the reservoir at the same time, while the engine runs.........
Schurkey
05-10-2019, 11:37 PM
ABSOLUTELY flush the PS fluid!
Once the fluid is flushed, install a filter to take care of any remaining bits.
https://www.napaonline.com/en/p/PNB351004
https://media.napaonline.com/is/image/GenuinePartsCompany/NWMDC?$Product=GenuinePartsCompany/1471439
https://www.napaonline.com/en/p/PNB351002
https://media.napaonline.com/is/image/GenuinePartsCompany/NWMDC?$Product=GenuinePartsCompany/1327024
They're sold by the hose diameter they fit. ^^^ These fit 3/8 return hose. there's other styles, but they're all about the same deal.
Tech II
05-11-2019, 08:26 PM
Good to know!
