Check engine light flashing
bikernut
12-27-2018, 03:43 AM
I have a 2003 GMC 3500 4x4 with a 6.0 engine. Problem: when plowing snow, hauling a small Kubota tractor or just driving down the road when the engine RPM gets to about 2200-3000 the check engine light starts flashing, I let off and reduce RPM and it stops flashing. What I have done so far is replaced the knock sensors 2 times, changed all 8 coil packs, 8 spark plug wires and 8 spark plugs all GM products no aftermarket stuff. I have gone to the local service station and had the scanner installed and driven it to the RPM and it says misfire in about 4 cylinders. When the light flashes it won't set a code just flashes and this is about to drive my crazy. The engine idles nice and smooth and when the light starts flashing at the RPM there is no roughness to the engine at all. Anyone have any ideas?? I have even gone and disconnected both batteries for a 24 hour period. Do I need to go to the GM Dealership and have the computer erased or re-flashed?? I'm at a loss, truck only has 45,000 miles.
Tech II
01-02-2019, 01:58 PM
When that CE light starts to flash, that is a misfire and should set a misfire PO300 codes or an injector code.....
A scan tool attached while the CE light is flashing, would be a great help....it would pin point which cylinders are actually misfiring......since you have replaced the secondary ignition parts(plugs, wires, coils), I am leaning towards either fuel pressure, a vac leak, compression or injector problems.....
