1995 regal heat
cumax57
10-07-2015, 04:53 AM
no heat installed new heater core hoses checked all inlets outlets for blockage
new thermostat new radiator. still no heat. would appreciate any suggestions
brcidd
10-07-2015, 08:37 AM
If temp doors are okay and heater hoses are NOT warm, then you need to bleed the air out- use the bleeder screw on top of water outlet (thermostat) housing. Or sometime it helps to "preload" system- unhook hoses and prime them with coolant.
Tech II
10-07-2015, 09:36 PM
Agree....air bound or a temp door problem....
