96 chevy blazer overheated
MicheleLeigh
10-04-2015, 06:18 PM
96 chevy blazer overheated did compression test number 3 was low on compression. And number 3 misfire. Need help with diagnosis please.
j cAT
10-08-2015, 08:52 AM
blown head gasket. when the gasket blows the coolant gets air bubbles in it . then the water pump can not pump the air.. so it over heats. typical head gaskets failing are from a poorly maintained coolant system.. drinking water and coolant cause scale and damage.. distilled water and 60% antifreeze works best .. also replace the cap. could be radiator needs some help.
