2000 town & country transmission issue? HELP
1987ss
02-05-2015, 04:34 AM
My wife has a 2000 t&c with 150k on it its a fwd with 3.8 and about a month ago while driving we noticed the rpms will jump up 400 and go back, with cruise control on or off being held at a consistent speed. and about for days ago it started shifting late. Still has all gears fluid looks o.k. and is full no check engine light . Im hearing transmission solenoid, tps sensor, input sensor, output sensor, tcm, iac, map, or egr are all possibilities or a rebuild . Or simple as a flush.. tonight i went out n started it it idles around 800 tried to hold it at 1200 and it would for a second and drop back to 800 with accelerator being slightly held. Not sure if related. Just observed it.. PLEASE HELP!
RIP
02-10-2015, 05:40 PM
Was hoping someone more knowledgeable would jump on this but, here I am. It sounds engine related since you can see it stationary in your driveway. It sure sounds TPS related to me. Have you tested it?
1987ss
02-11-2015, 02:10 PM
Thanks for the reply!! I haven't checked it, I guess i was hoping someone experienced same issue. Ill start there then. Thanks
