2008 Sebring Limited-mutliple warning lights
Deflep
11-19-2014, 08:03 PM
I have multiple warning lights on , Engine light, Brake light, ESP/BAS light, and ABS light on, also the speedometer stopped working . This all happened at the same time . Strange thing is the car runs great and havent had any other problems. Could this something as simple as a blown fuse or will it require a mechanic to diagnose and repair it ?
Scotty89
02-15-2015, 09:20 AM
The brake, ABS and BAS light are on probably for the same issue, a lot of the times these three lights come on together. The engine light could have something to do with it but usually with an ABS issue, the engine light doesn't come on. You could take it to a local parts store and see if they can check ABS codes. From my past experience, I doubt it is a blown fuse. Could be a wheel speed sensor, a bad wire somewhere or possibly a control module. The best thing to do is have the codes checked and go from there.
Deflep
02-15-2015, 07:54 PM
Thanks for your reply . It turned out to be the ABS control module
