rough/shakey idle at a stoplight.
cind3.8
06-26-2014, 04:48 PM
I have a 1988 Buick PA Electra. Car idles rough and shaky at a stop light. When warmed up service engine light comes on for a few seconds then goes off. I've changed ignition coil box, wires, plugs, ignition module, fuel injectors, fuel filter. It seems like there may be a vacuum leak. Please help. Car has only 114,000 miles on it and I don't want to give up on her. Before this she was running smooth. Thank you
Tech II
06-27-2014, 07:28 AM
Well, can check for a vac leak with carb cleaner, spray around the engine, vac lines and joints, to see if there is a change in idle...
If the CE light comes on, this means a code is set.....can jump A to B in the ALDL connector, key on, engine off, and read flash codes....
http://wbo2.com.au/~techedge.com.au/vehicle/im/con12pin.gif
Take the palm of your hand and tap the MAF sensor to see if there is a change in idle or stumble.....
Check fuel pressure? Last time the fuel filter was replaced?
cind3.8
07-01-2014, 02:22 AM
Will check for vacuum leaks. Now the car started making a loud clattering noise. Like metal clattering noise. I had to drive two footed to keep it running as I pulled into my parking spot, the car stalled. No check engine light came on that time. Since then I haven't even started it. I figure it could be a sensor. Also my AC/Heater display keeps blinking randomly on every setting. Something electrical?
cind3.8
07-09-2014, 06:10 PM
Please advise me on the location of E C M on my 1988 park avenue. I have one on the way and would like any expertise on where it is and any other issues to do with installation. Thank you.
cind3.8
07-17-2014, 05:27 PM
New update on 1988 buick PA 3.3. I had someone come and drive my car around the block. At corner near my house there started a metally clattering noise. People were saying its internal motor problem, blown head gasket, rod knocking. Which I just had to laugh. I have excellent compression, car never overheated. Noise was coming from pulley area. Noticed bottom pulley harmonic balancer peice in middle was worn causing the metal clatter noise.
I haven't installed ECM. I;m going to change balancer first.
Also one more question: Is the O2 sensor supposed to feel all loose? Like you can wiggle it back and forth? Please let me know.
thank you again for the previous replies.
