change oil light will not reset Grand Caravan 2013
venturenot
03-30-2014, 03:29 PM
The change oil light on my 2013 will not reset. I have tried the routine advised in the manual - turning key to on/accessory and depressing the gas pedal slowly 3 times turning to off and then starting but it does not work. Any ideas?
aleekat
03-30-2014, 03:52 PM
Same procedure 07 buick. Takes several attempts before it will reset. Try going faster.
venturenot
03-30-2014, 03:59 PM
Geez.. very frustrating. I have tried it about 10 times, sometimes slow sometimes quickly. I even removed the key after off position to see if that would work. Is there a sensor that could have gone bad?
aleekat
03-30-2014, 04:35 PM
Doubtful. Just did this yesterday, took over 10 tries to get mine to reset.
venturenot
03-30-2014, 06:56 PM
Thanks .. got it .. all is well.
aleekat
03-30-2014, 07:52 PM
Well the first time this happen to me, tried all day. Wife kept b****ing about the light. Friend stopped(mechanic) 1st try, it reset. Go figure. He did exactly what I had been trying.
venturenot
03-30-2014, 08:53 PM
I hate to admit it, but my mistake was that I thought that there were 3 key settings: Off --run/ accessory--start. I found out that there are actually 4 key settings. Off--accessory--on/ run--Start. It is real easy to move from the 2nd setting to 4th without even realizing the 3rd. Any way I found the 3rd setting and it worked the first time. So I guess all is well, and a new lesson learned.
Thomas Sams
04-05-2014, 12:38 AM
To reset the oil change indicator system hope oil is not leaked,Turn the ignition switch to the ON position this also very helpful to you,Turn the ignition switch to the lock position..
