faint antifreeze smell
Ehrmy1
12-30-2013, 09:21 PM
I recently purchaced a 09 Silverado with 73,000K and have periodically noticed a faint Antifreeze smell outside the vehicle near the engine when I park it in the garage. I cannot find any leaks and have not added any coolant. It does not smell inside the truck. Could a pinhole leak do this and not easily show up? Any way to test for this. Any thoughts on this would be appreciated before I take truck to get this checked out.
rhandwor
12-31-2013, 07:19 AM
Go to Advance Auto or Advanced Auto and get a loaner pressure tester. Pump it up to around 12 psi use a flashlight and look for leaks. Look closely at the weep hole on the water pump. Look for anti freeze deposits as sometimes these will drip and stop for a couple of weeks before going out completely. Look at heater hose connections as they will sometimes leak. Look at coolant hoses and radiator seams.
j cAT
12-31-2013, 10:06 AM
don't know what engine but the water pump gaskets do leak like this and hard to see any fluid drips. use the coolant dye . then with a black light see if you can locate the leak. I would re-torque the water pump bolts. check the thermostat housing also .
