99 Stratus ,new timing belt won't run, cam sensor?
barrelboy
11-18-2013, 05:42 PM
I changed the water pump and timing belt on my 99 Stratus with a 2.4 engine. As far as I know the timing marks were lined up when I put the timing belt on. Now the car will not start.
It WILL start if I unplug the cam position sensor.
What gives? Any help would be great
Thanks
Thanks
spike1269
03-17-2014, 05:53 AM
I had kinda the same problem with mine when I did it, You say that the timing marks are on? I know that when I put my timing belt on mine, I had to take it back off and took three times to get the tension right and the timing marks correct. I would double check the timing marks. I also know that I took the coil pack off and or unplugged it, make sure that something simple and little didnt become unplugged.
spike1269
04-09-2014, 04:17 PM
I did the same thing, three times it took me to get it right with the timing marks.also left the coil pack unplugged. plugged in and fired right up...
