Transmission? problems
ipec
06-17-2003, 02:22 PM
When the outside temp reaches about 80 degrees, my '00 Ford Focus SE starts to hesitate, and slip in higher gears (not wanting to catch when shifting), and really wants to kill when going about 5 MPH. I was told that the tranny fluid is foaming, and the line needs a flush. I did add some of that TransMedic/sealant stuff, but did not help. This only happens on hot days, and I'm very scared of having it kill on me when I'm doing 60MPH on the highway. Could this be the timing sensor too? Or could it be a leak in the fluid, or does this "foaming" cause these symptoms?????? Any and all help is greatly appreciated.
Racincc85
09-18-2003, 09:54 AM
The foaming definatly causing that. When the fluid foams, it becomes filled with air and can no longer be circulated through the transmission. This causes a loss of pressure to the clutch packs, etc resulting in slipping. Slipping for an extended period of time can cause severe transmission damage. Foaming fluid also causes the tranmission to overheat, causing even more damage. As to why the fluid is foaming, the trans was probably overfilled with fluid. i would get the fluid drained and refilled to the proper level asap.
