No Sound from Door Speakers 2007 Silv
wagslick
11-01-2013, 04:54 PM
I start my truck up today and there is no sound from either door speakers. No crackle, hum, or nothing. Tweeters work great, extended cab speakers work fine. I read in another forum that it could be due to rain. It did rain all night. How can I protect future speakers?
I have 2007 Extended cab z71.
j cAT
11-01-2013, 07:39 PM
the door interior should have a plastic shield. you use some double stick tape .
oem speakers are of the lowest quality
grice
01-05-2014, 02:43 PM
I have the same issue on my 2006 silverado, Front door speakers just produce a faint noise and the odd time they kick on fully. Loose wiring perhaps ? but I can't seem to find it.
j cAT
01-05-2014, 03:03 PM
remove the speakers and check for bad speaker. use ohm meter check coil resistance . with radio on tap speaker and see if it cuts out/in..
as was mentioned many times before these are of the lowest quality...
also use some plastic for a shield ... 6 mil is strong to handle the stress..
