91 crx wreck
wantacrx
06-12-2003, 11:47 AM
i wrecked my car, as it says in the topic. i just need some opinoins on what i should do with it, it's not totaled,but it will take quite a bit to fix. all the things wrong are ...front right fender ( i have a new one, aftermarket) front right lower control arm (also aftermarket) front right stabilzer bar ( got at junk yard) anti-sway bar (ordered from neuspeed) sunroof is screwed up & unaligned. the main problem is yesterday i looked under the car, & im not sure the name of the part,but it connects from one side right behind the tire on the right , to the other side behind the left tire. this "part" is welded in one spot that i can see and is also bolted to the body and it unwelded it self because of the wreck. should i fix it and get a shit load of body work, or keep it & part out, or sell it with everything ? thx , sorry such a long post.
fredthedragon
06-12-2003, 01:45 PM
hey dude i'm no expert but just went through the same thing. and what i decided to do was hunt for a clone and swap over the parts that i like best, i swaped my trannie and engine and seats couple of other parts too and i feel like i got my old baby back.
the thing you really have to look at is is the frame bent, if so it's gonna cost a crapload to get that fixed but if you have the money do it, what you gotta look at is how much you value the car, mabey you have some really fond memories from it (like mabey if you lost your cherry in it in one way or another). but personally i'de buy a clone w/ a good body and swap out, also weight the swap out cost versus the reparing cost.
hope that helps, good luck.
wantacrx
06-13-2003, 12:56 AM
thx for the reply. i do have some good memories in it, i've had a lot of fun w/that car. i wish i had some pictures to show you guys so u can understand the boat im in. ill try & get some and ill repost the subject, i really need some help from ppl that have had this problem. i found a car to swap all my shit into, a 91 red si hb. but it's not ne thing specail, went through a hairlstorm & rush on the fenders. i really dont wana spend ne more money on the rex if the alignment is guna mess w/me from now on. there isnt any frame damage, except for that one part. ill put up pix asap. thx again
