Need Help Badly
BLU CIVIC
06-11-2003, 10:34 PM
started to install this push button ignition and went to autozone to look at a helnes didn't really help so i decided to do the project anyways...guess what it didn't work....now i need help cause my column is tooken apart and i already stripped some wires and don't want to do anymore till i know itz right.....
these are the wires i need help identifing:
1- connect red wire of the relay to the constant power (12v)
(+) wire (or directly to the battery's positive terminal)
2- connect yellow wire of the relay to the ignition wire
3- connect the white wire to the starter wire
that's what the direction say and i need help identifing them.....help me plz :D
BLU CIVIC
06-11-2003, 11:01 PM
:feedback:
90civicrider
06-11-2003, 11:08 PM
1 - there is a 10 guage solid white wire in there somewhere thats the constant 12v
2 - not a clue
3 - MAYBE BIG MAYBE the yellow wire (will be by the 10guage white wire) If i were you go out and buy a volt meter and test all the wires before you start cutting them. Just to stay on the safe side.
BLU CIVIC
06-12-2003, 07:37 AM
already started cutting:frown:
sastanley
06-12-2003, 08:34 AM
put that shit back together and use your key like regular people do :wink:
95civicman
06-12-2003, 10:15 AM
ok i have a autozone one too...
go up to the ignition switch wires..
1.yellow goes to a black wire with a yellow strip down it.
2.white wire goes to a black wire with a white strip down it
3.red goes to constant 12 v.
4.black goes to ground.
if i had a digicam i would show you but i don't:frown:
BLU CIVIC
06-12-2003, 11:17 AM
ok....cool....got the 1st 2 right...so which one's the 12v?? is it that huge white wire??
amy@af
06-12-2003, 11:30 AM
http://www.binghamtonlife.com/manual/2gem/default.htm
MIGHT (being the keyword) have info you need
BLU CIVIC
06-13-2003, 07:40 AM
HURRAY FOR ME :ylsuper: :ylsuper: :ylsuper: :bananasmi :bananasmi :bananasmi
GOT IT WORKING....itz really a 30min job when u know what ur doing....don't have a digi cam so i don't have any pictures...i mounted it in that big square that's at the lower right that's beside the steering wheel....i poped it out, put a hole in it and mounted the switch....would tell u how i put a hole in it...but lets just say it was "ghetto rigged"....always remember to disconnect the battery when cutting into the 12v wire :icon16: but i'll try and take a picture for future reference
Stali08
06-13-2003, 08:21 AM
ha ha nice, yea make sure you get a digi cam, or something. Hey just get one of those disposable cameras where you get the cd back with your pictures, and use that, are you too cheap? :loser: ha ha j/k So is it the kind where you have to have the key in to start it? or can you just push the button and ladeda.
BLU CIVIC
06-13-2003, 10:04 AM
turn the key....friend who help me (and showed me how to hot wire it) said i could install the switch where u don't need a key....but said it is cool but u can't get very far b/c the steering wheel would lock.....
btw...to cut the hole i used a knife that i heated to cut thru the plastic...made it real easy:spit:
Stali08
06-13-2003, 10:05 AM
how much did you pay for it?
BLU CIVIC
06-13-2003, 10:19 AM
$30....but it doesn't light uo...gonna go to home depot or radio shack to get a light up switch
Stali08
06-13-2003, 10:36 AM
oh ok, so its not the s2000 push button one?
BLU CIVIC
06-13-2003, 10:40 AM
nah...i think those are more expensive.....but i'd like to get an "H" on the button....same one as in picture but i didn't use that mounting ring and i changed my button to blue
