High temp.
Civic DOHC
06-10-2003, 06:55 AM
My radiator temp is startting to rise everytime i stand stil voor a short time. The problem is that the cooling fan on my radiator doesn't turn on anymore. Is a temp sensor the problem en where kan i find it?
My car is a civic '89 ed7 with a d16a9 (ed9) build in.
Civic Jim
06-10-2003, 06:58 AM
well check fuses, then the wires to the fan with a circuit tester to see if it is live, if not then flush your rad and check the levels, hope it helps
cheerz
Jim
sastanley
06-10-2003, 09:21 AM
The temp sensor for the cooling fan is on the back of the block...near the oil filter, and the oil pressure sensor....It will be hard to see because of the intake manifold..it will prolly be easier to locate from under the car looking up behind the oil pan...it has two little prongs for the wire connections coming out of it about 15mm long. It requires a large wrench (or maybe a deep socket) to get it out...if I remember it is like 21 mm or larger!! :bloated: - I removed mine with a pair of channel lock pliers (vice grips may work too since they lock) because I don't own a deep socket set that large.
I think the fuse is in the engine compartment in the main fuse box.
Phact
06-10-2003, 12:05 PM
this has happend to me too :(...i feel ur pain
Civic DOHC
06-10-2003, 12:19 PM
It sounds like it is a lot of work.
sastanley
06-10-2003, 02:26 PM
it is more a pain in the ass than a LOT of work. :bloated:
You'll need to get the car up high enough that you can literally almost climb under it to get back that far...Once you are under there, it should be fairly visible. just pull the two wires off then remove the sensor.
FourthGenHatch
06-10-2003, 02:37 PM
For things like that I suggest buying a properly sized socket or a specialty socket for such things. I never like to use any type of pliars to get off something that may be stuck on pretty hard because you risk stripping it and that will ruin your day.
KoRnSaQ
06-10-2003, 04:21 PM
I had the same prob. with my 90 hatch. I finnaly figured out that somethin was wrong with the wiring or somethin. SO what i did was Hook a Toggle switch to the fan. now i can turn it on or off whenever i feel like it, so when the temp goes up i turn the fan on and it goes right back down..
civickiller
06-10-2003, 08:00 PM
i did the same thing with the toggle switch, just dont foget to shut it off everytime. dead batteries suck
i_a_n112784
06-10-2003, 10:54 PM
I had a similar problem with my fan not turning. I had checked all the fuses, they were all fine. It turned out to be the fan's relay. It is a real simple job to replace it.
sastanley
06-11-2003, 09:07 AM
Absolutely...I don't recommend using the wrong tool for the wrong job either...so if I didn't imply it, get the right tools!!! :thumbsup:
Also, someone mentioned the relay...don't really know how to test that unless you have a manual that tells you what type of voltage readings you should be expecting. :frown: - but you could probably swipe one of those from a junkyard pretty cheap. The radiator fan relay is right behind the passenger side headlight (there are two relays there) - it is the one closer to the stock airbox. Sometimes those things get stuck too..make sure the wires are connected well, and whack it when you think it should be running...sometimes knocking it loose will fix it too :wink:
cyberrexer
06-11-2003, 09:11 AM
If you still run this setup then wire it up to the ignition so that it only gets power when the key is in position II.
sastanley
06-11-2003, 10:12 AM
NICE! - Excellent idea...i did that with my fog light switch, cuz I always forget to turn those bitches off :bloated:
KoRnSaQ
06-11-2003, 04:00 PM
Actually i hooked my toggle switch to the headlight fuse. I always have my lights on when i am riding so i figured that would be the best way, and that way when i turn the lights off there is no power to the switch.
Civic DOHC
06-12-2003, 03:26 AM
Thank you for the info. I have been seeking that relay near the headlight. I am sorry to say that i havend't found it yet. My car is a european civic 1600 16v.
sastanley
06-12-2003, 08:11 AM
You mean the fan motor relay? I can probably find one of those pretty easily around here...next time i am at the junkyard I'll try to hunt one down...there are quite a few 4Gs locally that should have that kind of part.
i_a_n112784
06-12-2003, 10:22 PM
Try contacting a honda dealer, they should have what you need. I wouldn't think that it would be very expensive because it is a common part and they tend to use the same relay for many applications (different years, etc..)
chopstick1981
06-12-2003, 10:43 PM
try hot wiring the fan directly to the battery just to check if the fan motor is still good
Civic DOHC
06-13-2003, 06:59 AM
I already checkt the fan motor. its ok.
