98 century
chasbox1
08-22-2013, 05:24 PM
Hi
What is involved with changing the Control Arm Pivot Bushing both front and rear. That's where I think the problem is.
Thanks
SleepyHead98
08-22-2013, 07:02 PM
Hey, I would go head and replace the entire control arm. For one, you can get them dirt cheap from ebay, Moog brand. Two, you will get all new bushings Including the ball joint bushing. Three, You wont have to worry about the control arm bushing housings being warped or worn out because of the previous bushing rubbing around inside of it. Just my opinion. I just did this on my car 98 olds cutlass/chevy malibu
48 bux for moog arms all new.
Requires probably removing lower bolts on strut, removing cv axle nut. Of course removing the three bolts that hold the arm on( 2 botls one nut for the ball joint)
You will need a torque wrench and probaly two jacks, so when you go to torque the bushing bolts, the control arm will be up and level like it would be on the ground. You dont want to torque it with out the car weight/arm being level. \
EDIT forgot, more than likely you will need an alignment afterwards.
chasbox1
08-27-2013, 12:56 PM
Two new control arms ordered.
Thank you
gmtech1
08-27-2013, 07:09 PM
As Sleepy said, don't forget to get the alignment checked after you replace the arms!!
chasbox1
08-27-2013, 09:14 PM
Will do.
Thanks
chasbox1
09-20-2013, 04:04 PM
Finally installed the control arms. The sway bar bolts were a bit of a PITA . We replaced both. Tomorrow going for alignment.
Thanks again.
stripe
09-21-2013, 02:16 PM
Do not forget to lube the Ball Joints.
Cheers
Stripe
Tech II
09-21-2013, 03:58 PM
OEM's don't have grease fittings...
