front wheel bearing question
ericn1300
08-14-2013, 11:51 AM
Can you replace just the wheel bearing or do you need to buy the whole assembly? http://www.autozone.com/autozone/parts/Duralast-Wheel-Bearing-Hub-Assembly-Front/1992-Oldsmobile-Bravada-AWD/_/N-j488iZ6o2ny?itemIdentifier=972548_0_0_
gmtech1
08-14-2013, 04:37 PM
You have to get the hub/bearing as a unit, that's how it's serviced.
Chris Stewart
08-14-2013, 09:14 PM
Yup, mine was the complete hub. It also had a pick-up for the ABS tone wheel but the wire was crappy and broke about a year later. Pack rat that I am, I found the old hub, took the stock pick-up from it and installed it on the new hub....still there too.
ericn1300
09-05-2013, 04:35 PM
ended up that the bearing was just loose but for $30 bucks we replaced it anyways, it only has about 290k on it. Also found a bad lower ball joint and a missing lug nut, won't be doing business with that tire shop again.
Tech II
09-05-2013, 06:38 PM
$30 for a bearing? You will be replacing it again....
Chris Stewart
09-05-2013, 08:34 PM
Hope they didn't booger up the stud.
