2010 Grand Caravan Humming noise
luisbe
08-05-2013, 07:38 PM
This a 3.3L engine although the noise has nothing to do with the engine but front left near tire assembly, what can it be?
I appreciate your feedback
gmtech1
08-06-2013, 02:27 PM
If the tire is chopped, I will cause a noise. If the tire is ok I would suspect a noisy hub bearing.
luisbe
08-06-2013, 05:30 PM
Is it too serious? I'm so busy I can't take care of it after 20 days. Driving daily.
Thanks for your reply
BTW, tires are ok.
BTW, tires are ok.
gmtech1
08-07-2013, 07:46 AM
BTW, tires are ok.
If it is a bearing, it will only get worse and may eventually lock up or come apart. I recommend getting it fixed in the near future.
BTW, tires are ok.
luisbe
08-07-2013, 03:31 PM
Thank you gmtech1 (http://www.automotiveforums.com/vbulletin/member.php?u=683073), I will.
hundahunta
08-15-2013, 01:52 AM
check with your dealer the front wheel bearing have an factory extended warranty on some model years i think 08-10
luisbe
08-15-2013, 07:03 AM
I will but mileage is high so maybe that has a limit I guess. Thanks
