2003 Tahoe A/C Unit Brand New
randysnyc
07-24-2013, 05:52 PM
Had a new Compressor Drier, Tensioner and belt installed 3 days ago and the system worked great until today. In transit I heard a sound almost like a paper bag being popped then smelt the freon smell and the ac stopped blowing cold air. Any ideas what that could be? I have a 2003 Tahoe 5.3 engine with rear air.
gmtech1
07-24-2013, 06:44 PM
Sounds like a seal or line blew out. Possible the high pressure relief valve on the back of the compressor popped open also. Look on the compressor for a/c oil/dye. Will be all over the place. Also, if there is a pressure switch on the back of the compressor, the retaining ring may not have been completely seated and the switch blew out of it.
randysnyc
07-24-2013, 09:53 PM
There was a fluid all over the place when I looked around the compressor. Is this typically an easy fix? Just spent a bunch of money replacing it all and very bummed over it happening.
gmtech1
07-25-2013, 09:42 AM
Need to find out for sure where the leak was from. Some of the relief valves were replaceable, some were not.
Did you possibly overcharge the system?
j cAT
07-27-2013, 09:26 AM
too much refrigerant will do this . if you did all this work what was the high side pressures when charging the system @2000rpm. if this was not done and you charged on / in cooler temps you can very easily over charge.
as mentioned could be anything. I would add a can of regrigerant and look for leakage system off 1ST. then is necessary start system and find the leak.
you got a new seal kit ? also you must use refrigerant mineral oil on the seals not PAG 150 !
