1/12 Ferrari F40 GTE Evo2 kit build - JJ
JeremyJon
07-05-2013, 01:39 AM
I call this the "Ugly Duck" build, because of the donor kit we'll be using, the infamous Monogram F40 kit!
This kit, like many others, has been sitting in the back of the closet, due to the horrible body, so never intended to be built as is, so instead I decided to use this opportunity to use as a donor, and with some work of my own, make as basis for an affordable transkit, and have a decent looking large scale F40 GTE Evo2 on my shelf! :)
To that end, this will be a "best" possible build, not a super detailed build, given some compromise of the donor used & for reproduction, rather than being an all out scratch build, but I also have planned 2 stages:
Stage 1, body/glass/wheels/tires
Stage 2, interior/engine/brakes
The basic chassis & suspension of the Monogram kit are half decent, the interior shell usable, and measurements are fairly accurate, but when it came to the body, it's as if they just didn't care about being accurate?! :dunno:
You can see right away how much material has to be removed and altered, and why I call this a "duck", as the nose was 1cm to wide? :headshake
I was originally hoping to re-use the glass, but once into the build it became obvious that new ones will have to be vacuformed!
So, first installments, Enjoy! :)
[/URL]
[URL=http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/944181_472237876203260_1868234217_n1_zps8a649614.j pg.html]http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/944181_472237876203260_1868234217_n1_zps8a649614.j pg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/944181_472237876203260_1868234217_n_zps546c0d37.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044569_472239156203132_777641268_n_zpsbd11e5c8.jp g (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044569_472239156203132_777641268_n_zpsbd11e5c8.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241282869586_2132332384_n_zps444d5c97.jp g (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241282869586_2132332384_n_zps444d5c97.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241289536252_1334787955_n_zpsaef104cf.jp g (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241289536252_1334787955_n_zpsaef104cf.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241292869585_632460553_n_zps7658fde6.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241292869585_632460553_n_zps7658fde6.jpg .html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241296202918_814291693_n_zps66066cca.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/995424_472241296202918_814291693_n_zps66066cca.jpg .html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044935_472242512869463_366971220_n_zpsc32f5d25.jp g (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044935_472242512869463_366971220_n_zpsc32f5d25.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/970051_472241669536214_1725841688_n_zps0c5c4e4e.jp g (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/970051_472241669536214_1725841688_n_zps0c5c4e4e.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044935_472242516202796_855941293_n_zps281d22d7.jp g (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044935_472242516202796_855941293_n_zps281d22d7.jp g.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044935_472242519536129_1070448732_n_zpse2418d0f.j pg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/1044935_472242519536129_1070448732_n_zpse2418d0f.j pg.html)
[/URL]
nugundam93
07-05-2013, 11:06 AM
looking forward to this, especially since i have my friend's semi-junked 1/12 F40 that he'd like fixed and i still don't know how to proceed, aside from disassembling it.
avd
07-05-2013, 12:56 PM
Wow that body in bad shape. Sure need a lot repair. Look cool tho.
JeremyJon
07-05-2013, 04:52 PM
Thanks guys! The original body is very poor design, but has enough content to use in modification, rather than to completely scratch-build, and in keeping with this projects idea, to keep as affordable as possible in the end result
The photos don't show completely the degree of cutting/channeling/splicing involved, the roof alone I had to splice from 12 separate pieces
When I glue them back together the seams mostly disappear, but this is all in an effort to minimize the filler layers, so the basic forms and shapes are brought as close as possible this way first!
Some further work done, starting on the front end now, which also required a large degree of modification
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/june29005_zpsc3e5c303.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/june29005_zpsc3e5c303.jpg.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/june29009_zps452fc173.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/june29009_zps452fc173.jpg.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3004_zps960693ae.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3004_zps960693ae.jpg.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3007_zps51611d34.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3007_zps51611d34.jpg.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3008_zps96f10cb3.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3008_zps96f10cb3.jpg.html)
http://i1296.photobucket.com/albums/ag17/ClearlyScale/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3010_zpsec2fbcd7.jpg (http://s1296.photobucket.com/user/ClearlyScale/media/Ferrari%20F40%20GTE%20Evo2%2012th%20scale%20transk it%20build/july3010_zpsec2fbcd7.jpg.html)
JeremyJon
07-07-2013, 09:21 PM
Whoa, just came across this image on FB, and couldn't help but drool! :smokin:
avd
07-07-2013, 10:41 PM
uhhhh I don't see it.
JeremyJon
07-07-2013, 11:20 PM
avd
07-07-2013, 11:26 PM
ummmm, sexy. Make just like that.
JeremyJon
07-08-2013, 12:19 AM
Front is the same, but rear wing is different for the GTE Evo2 version ...I'll leave it to you guys to paint what ever color you want! :)
lovegt40
07-09-2013, 08:00 AM
wow, serious surgical work here !
It seems already getting the correct shape.U are doing a great work and the real car is one of the best reds ever.
good luck, will follow closely ;)
John18d
07-09-2013, 04:27 PM
JeremyJon - excellent scratch building on this otherwise crappy kit.
Sad to say I have one of these in the collection - and until you pointed it out - didn't realize the kit was so far from scale.
I will follow your thread as it appears you're on the right track
John
John
JeremyJon
07-10-2013, 12:08 AM
Thanks LGT40!
Thanks John!
The kit chassis is decent, and drivetrain useful, so with a body/wheel/tire set, could be a presentable model build
Even better with a second interior/brakes/engine detail kit, but that'll be coming along after the first part is done
Besides, for a Kyosho LM version, it'd cost $500, and I'm not interested at that price, so this will be a MUCH more affordable option :)
Thanks John!
JeremyJon
07-17-2013, 01:48 AM
More progress, starting design of Enkei wheels - thanks to Johan - to be 3D printed, for this 1/12 F40 GTE Evo2 project! :D
indecentkikogt
07-17-2013, 11:45 PM
Great work, paint it like this :)
http://i1001.photobucket.com/albums/af137/4refig/8c369ebd508ad775bbd4a2a7974226a8.jpg
JeremyJon
07-18-2013, 01:56 AM
Thanks!
Oh no, I won't be painting it, just hard finishing primer, then making mold & duplicates from this master body
When I make one for my own shelf, it'll be F40 Rosso Corsa ;)
Thanks!
gtziaf
07-18-2013, 09:31 AM
Great start, to a difficult progress.
Good luck...
Good luck...
JeremyJon
08-01-2013, 06:04 AM
Thanks gtziaf!
I'll take some more progress photos soon :)
JeremyJon
08-26-2013, 12:06 PM
