New TPS, car won't start
Hosana
03-03-2013, 01:50 PM
I have a 97 Escort and recently started having idle problems. It would go up and stay up until I turned off the engine. It would also idle so low that it would stall out when I would stop at a traffic light. A TPS sensor code also appeared. I changed the sensor, but the idling problem continued. During the process of changing the TSP I also cleaned the IAC valve. The car would start with no problems, it just continued to idle rough, with the code returning. I researched how to test the TPS, did the test and discovered I had installed a bad(new)TPS. I reinstalled a new TPS and now the car won't start. WOW, one problem to another. :banghead:It will turn over, but it will not start. HELP!!!! What is going on?:confused:
Mike
Mike
rhandwor
03-05-2013, 05:44 AM
Mike
A lot of TPS sensors have some adjustment look at the dirty spot where it orginally set and put the new one on the same spot.
Mike
swingline
03-05-2013, 07:07 AM
The car should start with a bad TPS unless it's reading WOT which would put it in clear flood mode. Unplug the tps and see what happens. Check for spark.
ben.na.walker
03-26-2013, 09:18 PM
Same situation on my 98'. Replaced TPS still no better. Now it actually over-revs. I've never been so... stumped with an engine before. More ideas to the problem would be seriously... seriously appreciated guys. Thanks! .
rhandwor
03-27-2013, 04:53 PM
Try checking for a vacuum leak around the Pcv line. Clean the Iac valve.
hakachukai
04-24-2013, 12:39 AM
I cleaned my IAC one an 94 Escort once and it caused a no start condition with no code. The reason why is because the sensor got wet with the cleaning fluid that I used.
Try unplugging the IAC and re-testing the TPS.
If that fails try unplugging both the IAC and the TPS.
Post back and lets us know what the results are.
See this post about how a wet IAC can cause a no start condition: http://www.automotiveforums.com/vbulletin/showthread.php?t=1087028
