Passport Issues
taet1971
12-13-2012, 12:35 PM
My 2000 Passport is really sluggish when taking off. It goes really slow and then eventually picks up speed. I was thinking it was the transmission but last week the car wouldn't start either. So we replaced the battery and then it started. Wondering if this is an electrical issue that is causing this and not the transmission. Help:confused:
amigo-2k
12-13-2012, 05:51 PM
Start with the basics like like plugs and the fuel filter. Also, assuming it is an automatic, pull the winter button out and unplug it and see what happens.
Isuzu's do odd things with weak electrical systems (dying alt).
If the truck is warm and when you try to start if after sitting for 30 minutes and all it does is crank and crank and crank before it fires up your fuel pressure regulator may be shot.
